Car starts up fine when cold but when it reaches operating temperature it turns off. If you try and turn it on again it just cranks but doesn't turn back on until the engine gets cold. What could be the possible issues? Now I replaced the Coolant Temp Sensor and the one next to it with new OEM from Z1. The car also smokes from the exhaust on start up. Car is on CT right now and I live in NJ. My buddy is looking the car over and was going to drive it to NJ last Saturday when it cut off on him when he filled it up with gas. Feel free to ask questions and I'll answer as soon as I can. Thanks! Car is a 1990 300ZX NA
Backstory: Bought this car almost 2 years ago and have been working on this very long/annoying/stressful project. I replaced/upgraded the following: 120K performed and timing set. Aftermarket eBay Headers Stock Cats HKS Exhaust Rebuilt MT Transmission 5SPD NA ECU (stock) Converted to New Style 270CC injectors Replaced Fuel Pump Silicone PCV hoses Deleted Carbon Canister Relocated Power Steering Replaced all fuel lines Brand new EFI harness w/ 12V mod and PTU subharness mod Deleted Coolant Lines under Plenum AIV Delete Replaced O2 sensors Completed 5SPD swap Brand New Clutch Cylinder Brand New SS Clutch Line Z1 E-Fan Wired Thermostatic Switch Brand New OEM Radiator Relocated Fuse Box under Headlight New Silicone Overflow Hose New Silicone Brake Booster Hoses New Silicone Heater Core Hoses New OEM PS High Pressure Hose New BMC brace New Z1 Exhaust Gaskets New OEM Rear Main Seal Resealed Oil Pan New OEM Coolant Temp Sensor and Spade Sensor (on hard pipe)
